chuckwhut said:
i haven't turned anything though. i "turned" the truck off...got out, and pulled the cover, haha. this is how it was when i found it.
Ah. So maybe you are a little ahead of yerself then. If you want to check out the slack and timing, get a 19mm bolt and turn the crank clockwise and then see how it it, thsi is more realistic. While yer at it set it to TDC so you can check the valves as Chase mentioned. This is a good way to assess if the chain it stretched or something, b/c when the crank is at 12:00 TDC, the notch/hole on the cam sprocket will be just shy of this, like 11:55. If yer off, it would be less than that.
As I said, do you have some reason to believe the oil pressure is low, or anything like that - or is it simply that you pulled the valve cover off just for the hell of it and check on those guides, saw a little bit of slack in the chain?
Chase, I do not mean to be an a$$ but want to clarify something you said b/c at first it was confusing to me. The driver's side, where the long guide rail is (that SHOULD be metal-backed) is in fact NOT slack when the engine is turning. This is b/c the crank is moving clockwise (as you face it) and is using that chain to pull the cam sprocket. Meanwhile the other (passenger) side is naturally slack when in motion, that is why there MUST be a tensioner on that side, to keep this slack away so that the chain is tight on both sides, and descreases chances of slipping a tooth.
When the engine turns off, crank will stop due to friction, and cam wil lstop b/c it's no longer being pulled by the crank. However if/ b/c there is a difference in the native friction between them, the cam may turn just a litte farther, causing the slack that is seen in the above picture.
The tension of the chain is the largest issue when you first start up the motor - there is a brief moment when the crank is moving faster than the cam , before the chain "grabs". if there were a whole lot of slack on the opposing side, thsi would be a great time to jump a few teeth. However since the chain tensioner is there, and spring loaded, it keeps this from happening - and of course once it has oil pressure, which is as soon as the crank turns at all, the tensioner is even more tight.
If you ever take the timing cover off, just spend a few minutes spinnibng that crank pulley around and you'll see how all this works. It's pretty cool. I am a real nerd so I find this entertaining.
Oh, and YEAH setting valves at full heat takes somebody that likes their finger a LOT less than me. It would be alot easier if they'd publish the intended spacin gat DEAD COLD, eh?
cperry said:
yes it is possible to do it without pulling head, put you disrupt the head gasket and oil usually leaks at the cover.Scheduled maintance i believe is every 100k.
And I still do not see how the head is the least bit disrpted in changing all the timing components. You can leave all head bolts in place, only one that is even related to the head is the Mystery Bolt and that only goes into the TC and not the block?
Toyota makes no mention of the timing chain as a maintanance service part, like timing belts are for many cars. The plastic guides wear out long before the chain itself does (assuming you change oil like you should).
