Slightly updated Taco pic
HardTaco
Durham
Put the old 35's on, repainted everything........still needed 37's, gears, and driveshaft...............
you can also see my super cool damage on the bed from tellico this year :p
looks good. By the way its like 12 and everything is closed on campus and I so want a taco right now and ur truck reminded me of taco bell..god im hungry :(
thats a taaaaaall mofo :flipoff2:
just kidding... looks good! now get some bigger tires to fill those gaps!
Josh, how far from the ground to the bottom of the frame in the middle? It does look tall, but damn, looking closer.. nice job on the fenders!! Very Scott Freas looking..
i dont have a measurement to the skid, josh will have to chime in on that one... but remember he does have that sexy budbuilt flatbelly under there :D
so it is a little tall, but hell, it's got wider axles...AND, you've got something to wheel again! :smokin:
Bud needs to figgur out a clocking ring for the back half of a single toy minitruck case.. :)
it looks pretty tall to me. bottom of the rocker panel is at the top of the tire. you could stand to lose 3-4" and still have plenty of room for 40's. right now it looks like you could do 44's If you moved the front forward more.
Maybe its the visual effect for you guys thats doing it. Its only 3.5 inches taller than it was before(6 inches of lift before)......................and the front axle is DEF. wider than the rear. From outer sidewall to outer sidewall on the tires now its around 81 inches. (2 inch BS wheels). Rear is about 76. These 35's are seriously worn too, and prolly measure out to a small 33. I used the no-lift type hanger that mikey did, and im using stock 7 leaf wagoneer springs. So basically mikey its almost the exact same as yours, with only 1.25 inches more body lift. I guess the fenders are what is doing it for you guys.......
Josh
Ive enclosed a pic of my truck before with 36's.............and 6 inches of lift.
Tacoma747 said:
Wider axles? I thought he just put a waggy 44 in the front. That is the same as stock (within 2" if it is the 63" wide axle)
I was comparing it to mine... and his axles are wider than mine, though he's quite a bit taller..
