SM465 tranny and Chevy V6 motor clutch??
One that fits the fllywheel that you're using
you might be able to use it. I think that your going to need quite a bit more info on this before you go out an buy parts. I would take a look at advanceadapters.com and see if they have anything on this setup.
By looking at advanceautoparts.com, it looks like the astro clutch is 11" in diameter, for a 14-spline 1" input shaft.
According to novak-adapt.com, the sm465 has a 10-spline 1-1/8" input.
The astro clutch will not work. Contact novak http://www.novak-adapt.com/contact/contact.htm
it will be the same as a chevy 350 & sm465 tranny. just look it up on www.rockauto.com
