mbalbritton
- Mar 22, 2005
- Orlando, FL
I have a Troy-Bilt 4 cycle Trimmer. It's about 3-4 years old and has always started on the 2nd pull until this season. As of right now It's takes a lot of pulling to get it to run and then it will only run for a few seconds. At the start of the season it would run, but it would only run at idle. anything off idle and it would die.
What I've done so far:
rebuilt Carb
swapped carbs
Checked plug
swapped fuel
Changed Fuel cap
Gone through carb 3 times checking for anything I missed.
It feels like it has good compression from pulling the cord. and when it runs, it runs good.
Only way I can get it to run right now is to spray starter fluid and wait about 2 minutes then pull it 6-8 times. Then it'll run for about 15 seconds and die.
It's really starting to piss me off. any thoughts?
rebuilt Carb
swapped carbs
Checked plug
swapped fuel
Changed Fuel cap
