RatLabGuy
- May 18, 2005
- Churchville, MD
Could this be a long-term effect of a poorly balanced tire? Just a random thought.
Elliott said:I know these pics suck but the lower portion of the studs on the wheel spacer are completley threadless. Apparently the noise from the locker was from the rear tire angling in and out because these spacers were not really bolted to ANYTHING. Never buy wheel spacers!
Rich said:231 - not sure why that would have happened, but I would guess that you were running std. backspaced wheels with large offroad tires.. which means effectively, you had less than 1" of backspacing (normal Toy wheel is 3.75" BS), putting nearly all the vehicle's weight on the studs in a way they didn't like.
Yes you are right on that. Im sure running 38.5 Boggers didnt help and the backspacing wasnt right but i personally will never run spacers again just because of the trouble i have ran into. Not only the fact of running down the interstate and having a tire come off but the hassle of spendint $200 to $300 dollars everytime it happened. Thats why i just wnet with full width axles and said to hell with the small axles.
