- Mar 10, 2005
- Hooterville (24171)
Since Junior wiped out the DD, I'm in the market for a decent spot-weld cutter. Don't need a "$100 model", but don't want something crappy either.
Local jobbers have what looks to be the same cutter...pointed "pilot" with double ended HSS cutter (can be flipped for renewed cutting teeth).
Whose have you used?
What do you like about it?
What don't you like about it?
How did it hold up? (IOW, is cutting 2 welds gonna smoke both sides of the HSS cutter... and I'll be looking for a carbide/cobalt equipped model to cut the 5 dozen welds I have)
