Spray / Roll in liner
UDT JEEP MAN
ROXBORO
Does anyone have any idea which type of spray or roll in liner to use?
I have been doing a lot of research on the matter and would like to see what everyone else have been using.
I have looked at Hippo, Rhino, Line-x, Bedliner, Durabak, Hercules, and SEM.
I am thinking of doing it myself and would like to know what everyone thinks about the work verse the $$$$
Hi, Im sure you have seen my tacoma around Roxboro. I used the Wal-mart roll on bedliner and its doing fine. Its all in the prep of the surface you are going to be covering. Its not as thick as some of the others, but that isnt an issue unless you REALLY REALLY abuse the surface you are going to be applying it too. Clean the surface, sand it, clean it, sand it, and clean it one final time.......its a pita, but mine is sticking and only coming up in one spot where i slammed the hi-lift down on it. My total cost was right around 52 bucks with a gallon of liner, brushes, rollers, sand paper and some grease/wax remover.
Josh
One of the first things I did to my '95 after tires and wheels was have the interior Line-Xed. It is going to cost alot more than a do it yourself job, but i have a lifetime garantee. I have thrown all sorts of stuff at it and and doesn't mar at all. If you do not have the self discipline to do it yourself like the above post, you might consider it. The prep work is the key to any of them. My buddy did his '01TJ. He thought he did a good job prepping. Its all coming up now. His interior looks like bright yellow and black camo. We think its funny, while he doesn't. Go with what you feel confident with. Either way lining your interior is awesome.
by the by, total bill, prep to finish was about$425!! Told ya is wasn't cheap!
