maulcruiser
- Aug 13, 2005
- Bladenboro/Wilmington, NC
I bought a Tacoma last week that hasn't been run in five years. I'm going through the steps to get it running again, and was checking to see if you guys think I'm overdoing it, or if it's a legit method:
Pull fuel tank and flush/clean system from tank to injector rails.
Pull spark plugs and inspect cylinder bores.
Hand turn engine to check if it's locked up or not.
Change engine oil and filter.
Use the starter with the plugs out and fuel pump fuse pulled to build oil pressure.
Reinstall new plugs and fuse to see if it will fire.
Think I'm skipping any critical steps for an initial test-fire?
