- Mar 10, 2005
- Hooterville (24171)
Well, the low budget towpig ('99 C2500 Suburban 5,7L/4L80E/SF "14B"/3.73/HydroBoost) has met with it's first hurdle...
Shortly after doing a test drive & thunking down $$ on it, I stopped at I-40 & 540 to put some fuel in it. Needless to say, the $30 I put in didn't do much in the 44 gal tank
Drove it back to GSO (spent the night) & notice a small "wet spot" in Taters driveway the following AM. Over the next couple weeks, I noticed that there wasn't a real pattern to the drip, but hoped it was a return line, leaky fitting, or something quick/cheap/easy to fix...
Dropped the tank this evening and my suspicions were confirmed... the POs had dropped the tank (44gal = 30"w X 36"l X 15"ish deep) down on something, caving the center in a few inches & putting a small buckle & crack in the rear of the tank just 3"-4" up from the bottom (below the seam)
Outside of the tiny crack, the tank is in VERY good shape (NO rust, crud, or other bad juju)
Based on it's location and NOT wanting to drop it again, what's the consensus on repair?...
1) Give some type of putty/epoxy a shot
2) Have it welded/brazed/soldered (not sure if my local rad/tank shop still does this)
3) Blow $300 on a new tank (1/6 the value of the rig itself)
Outside of the tiny crack, the tank is in VERY good shape (NO rust, crud, or other bad juju)Based on it's location and NOT wanting to drop it again, what's the consensus on repair?...
