obullfish
Carolina Trail Blazers
- Nov 21, 2011
- Candler N.C.
Finally found a use for those damn drop in plastic bed liners. Since it aluminum it won't rust your bed out either.
I have a stall mat in the bed of my Tundra to try to avoid big dents.
Supposedly, Ford built a fleet of aluminum trucks a few years back and sent them to oilfields, and Kentucky and wv coal mines for endurance testing. If they were satisfied with the results of that I'm sure there's nothing to worry about, I'm reasonably sure those guys are way harder on equipment than a standard construction worker, LOL.
I wonder how it would have held up to the test with a good spray in bed liner?
The tool box was surprising. That was a pretty real scenario.
Intuitively, the bed liner isn't going to absorb enough energy to prevent damage, and doesn't have anywhere close to the tensile or shear strength of aluminum, so I don't think it will have much effect on the major areas of damage. There is a lot of energy when a block falls like that, and the point of application is very small if it lands on an edge, corner, etc. It's all about load distribution, and the tool box is another example of that. Relatively light object, but damaging if the force is concentrated in one small area.
I'm not a Line-X fanboy, but it is a good product. I think Furd designers are counting on it to help add durability to the bed. Properly applied, it absorbs and distributes the impact. It also doesn't stretch much, so it will help with shear damage. A roll-on job from Advance probably isn't going to provide much more than traction, but a properly sprayed in Line-X liner would probably have changed the results of that test dramatically.
LINE-X Sprayon Bedliners, Protective Coatings, Truck Bed Coating, Floor Coating, Industrial Flooring
I think it will help with everyday bangs and dents and stuff, yeah. A block dropped from that height on an edge or a corner is a different story though.
Wrong thread, that one's here:I dont even have to go into control groups and dump speed, block weight, dump height, etc do I?
This is my thoughts...if you are moving enough block to need that size loader to load them, you will 999/1000 be loading it into a dump truck or at least a container much larger than a half ton bed.
I think you are too focused on material properties and are neglecting geometric boundary conditions. Draw a free body diagram and reanalyze.Intuitively, the bed liner isn't going to absorb enough energy to prevent damage, and doesn't have anywhere close to the tensile or shear strength of aluminum, so I don't think it will have much effect on the major areas of damage. There is a lot of energy when a block falls like that, and the point of application is very small if it lands on an edge, corner, etc. It's all about load distribution, and the tool box is another example of that. Relatively light object, but damaging if the force is concentrated in one small area.
Tapatalk just sent me a notification from a similar thread on another forum:
Skidsteer shoulda been 1-2ft closer, and why did they put all the stones on the ground instead of back in the bucket? Maybe I'm lazy, but I refer to is as "efficient".
Except for (I assume) the piece of paper that says they can't without license.That tailgate and trunk on there are pretty slick. No reason that couldn't be integrated in to a normal truckbed with some OEM ingenuity.
Underbed storage isn't a novel idea, and multi-direction tailgates are on other vehicles, so the patent would have to be so specific that it would be easy to tweak a little here and there and come up with something that does basically the same thing.Except for (I assume) the piece of paper that says they can't without license.
