Mathis Photography
- Apr 28, 2009
- Wilmington, NC
This weekend I took my steering box (Astrovan box, standard saginaw style) apart and drilled/tapped it for hydro assist lines. I was sure to get all of the shavings out before reassembly. Everything went together as it should and I put it back on the truck. Now at about 1/4 turn before full lock to the left it pops and then completes the turn. It does it even when disconnected from the drag link.
The steering wheel is also roughly 1/4 turn off, which doesn't make sense. As I'm going through the process in my head, the only thing that seems possible is that the power piston isn't lined up properly, but from my limited knowledge, it doesn't seem like it would all go back together and function if it isn't lined up.
I drove it around the block last night and it seems to be functioning properly and isn't leaking. Just making the pop and the steering wheel is off. I can fix that with the drag link, but it doesn't leave enough of the heim shank in the shaft.
Anyone have any ideas? I'm hoping to get some guidance before I take it all off again and pour another quart of fluid in the floor of my garage.
