Steering box leak
Nissan11
Marston, NC
How can I stop this leak? It did not leak when I had my old box on, but since I screwed out the fittings and put them in the new box, they leak. I thought they were leaking from the threads so I wrapped them in teflon tape, but the leak is actually where one of the lines meets the threaded fitting. How can I fix that? Since both of the fittings can be slid up and down the lines when they are unscrewed, how is the seal supposed to be leak-proof?
what is that new box from? is it the same as the old box? just wondering if your new box is set up for o-ring style fittings while you have flare-style hoses.
I would check to see if there was an O-ring on the line, if there is replace it, if not you might of mixed parts and are barking up the wrong tree.
