Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
It's time to replace the steering box, pump, and lines on my 99 Silverado 1500. I've got the famous "weak right turn" thing going on and it has only gotten worse since the SAS. What I've been looking at is replacing the steering box with one from a 2500/2500HD. The reasoning behind this is the design of the box itself. The 2500 box is much easier to use with hydro assist, which I will probably do in the near future.
Now then...I can verify that the sector shafts are the same (diameter) because the pitman arms are the same part numbers. I can also see that the inputs on the boxes are the same as well since they use the same steering shaft part numbers. The only thing I don't know for SURE is if the 3-bolt pattern where the boxes bolt through the frame is interchangeable.
Atsco 7588 for the 1500
Atsco 7587 for the 2500
Rock Auto has good pictures They appear to be identical and I think it's worth a shot! I realize that they may be different ratios or one may be fixed ratio vs. variable ratio. Shouldn't be a problem though.
If anybody else has some input on the situation, I'm all ears!
