Steering slop
james78
Jacksonville
I have a 2000 TJ with a 4.5 lift while driving at low speeds under 40 stees fine higher speeds wanders and pulls to the right.
I started looking the whole axle is moving slightly when stoped and turn the wheel back and forth but the axle bushings are tight and not ovled the stableizer bushings were loose I replaced them and a slight change but still wonders driving :confused:
Chech tire pressures....mine pulls hard under breaking and at highway speeds. I have found my front right tire leaks a little and needs air when it does this. Also, check a wheel bearing my friend had this in his T and it was due to a crushed wheel bearing.
Check your track bar mounts and busings, if they are worn or loose it will let the axle shift.
