steering
steven holbrook
asheville
I have a 1985 toyota pickup used specificaly for crawling. Put cross over steering on it, by welding aem the top of drivers side knuckle. Changed to a two wheel drive pitman arm. Turn great to the right but not so good to the left. I have adjusted tierod ends, still the same. is it possible the pitman arm is off one or two teeth?
I would check the pitman arm. Put the axle on stands and don't fully tighten it, make changes and see what happens.
Have you checked the steering stops?
