Sterling 10.25 ?
ncjeeper76
Climax NC
Does the Sterling 10.25 use gear oil from the diff to lube the wheel bearings ? I cant find anywhere there is a seal between the diff and wheel bearings and the hub was full of gear oil. I have to replace the inner wheel bearing seal after finding gear oil in the brake drum. Do I need to repack the bearings with grease or will it just be washed out by the gear oil ?
Thanks for any help
Jason
from what i can remember , you pour gear oil in the hub and put it all back together , correctly torque everything and fill the diff back to the top with gear oil. ive got a book and the correct socket if you want to borrow it. im not far from you.
