sticky zj gas pedal
stockzjwnc
Member
wnc
OK so i drove my jeep from Boone to Atlanta and on the way the gas pedal started sticking.I put 93 octane in it before leaving.Any idea why its doing this.
Take it to your local Toyota dealer!
Possibly is carbon or crud buildup on the throttle body, lack of lubrication in the throttle cable, or the pedal physically catching on something on the floormat or carpet. I'd start with the carpet because it is easiest to check.
If you pop the hood, you'll see a tube going from the airbox to the throttle body. If you pull that tube off the throttle body, you can see the throttle butterfly, and if the area around it is dirty looking, cleaning it may fix the sticking. You can buy carb/choke/throttle body cleaner from any parts store, which will break that stuff up, and maybe a toothbrush for the tough stuff. It is best to remove the throttle body so that the crud doesn't enter the intake.
check your shoe...
you might have gum on it,causing the sticking hahaha!!!!! just play around,wish i could help ya. maybe bad gas?
