slvrathlon
Member
- Mar 15, 2007
- Raleigh, NC
Something funky is going on in the rear end.
When at speeds over 30 or so when you are at any constant speed, if you just slightly let up off the gas you get a holing or rumbling noise from the rear end. If you give it some gas or start to slow down then the noise is gone.
There is no whining at all, when accelerating or deccelarating all is quiet, its just the threshold where you are at constant speed when torque is at a minimal to the rear end. I know what gear whine sounds like, it does not sound like that, so I guess that leaves pinion bearings or carrier bearings.
99' Cherokee
3.5 RE kit, but basically netted 4" (Possibly a lil higher). Ran no SYE, no Shims... had the shop put 4 degree shims in, along with a TC Drop and I guess it still makes a noise, not sure how much difference as I'm traveling and won't be back until end of week.
But is this basically only curable by adding an SYE?
Anyone recommend a good driveline shop in the Raleigh area?
Any ideas.
Thanks
99' Cherokee
Any ideas.
Thanks
