maybe clearance issues between wheel and rotor/caliper.
But what if it has drums?
I think it’s really trailer and vehicle specific. A lot of times you get a lot of surface area contact with the strap and the tire - especially offroad rigs with wide tires- and the rubber isn’t a solid secure point so it adds wiggle and the tire compresses or deflects.Resurrecting an old thread I know, but is there a reason nobody goes through rim around tire and ties down? Was looking at these.
VULCAN Car Rim Tie Down System with Ratchets - 2 Inch x 144 Inch, 4 Pack - 3,300 Pound Safe Working Load
The Only Way To Secure Valuable, Low Clearance Vehicles Specifically designed for low profile vehicles with exotic rims Harness has virtually no metal parts, reducing the risk of vehicle damage 12' straps for easy, damage-free tensioning Bold, professionawww.vulcanbrands.com
Muddy tires will just trash them.So what is the opinion on this style of strap? The over the tire straps?
Amazon product ASIN B07S6BYR4X
I saw them in action my last trip and thought they were a great idea. Am I wrong and should I just stay with traditional axle straps?
i just purchased those straps for my xj ive tried them around the wheel like they showed online it allowed my xj to roll on the trailer so i just run them through the rim and love itResurrecting an old thread I know, but is there a reason nobody goes through rim around tire and ties down? Was looking at these.
Tailgate or ramps up and send itwho straps their truck down?
Those are great til a tire leaks down while you are towing. I use them in junkers, but I watch them like a hawk.Resurrecting an old thread I know, but is there a reason nobody goes through rim around tire and ties down? Was looking at these.
Those look like you have to rethread the ratchet every time?Those are great til a tire leaks down while you are towing. I use them in junkers, but I watch them like a hawk.
Not if you go around the tire instead of through it. Although retreating the strap is soooo hard.lThose look like you have to rethread the ratchet every time?
Has anyone tried the shock-style straps? I can see the appeal, but not sure that I have had enough issues to warrant the extra cost.
Not hard, just more steps/time for securing your vehicle, esp when you are anal about how your straps are setup.Not if you go around the tire instead of through it. Although retreating the strap is soooo hard.l
I found 4 points (mostly control arm mounts) where I can run a 6ft chain and binder to 4 corners and be strapped down in less than 5 minutes. When you go wheeling as often as I do, it's important that it not be a major inconvenienceWeld on axle tie down brackets and forget the rest, under 10 minutes and no straps wearing out going around axles or replacing axle straps. Wasn't there a vendor on here that was making them?
RQ has his chain over the pumpkin about the same time too. Guess as long as it is always the same vehicle.
Or just roll down the windows and run the strap thu the vehicle, on the way to the scrap yard.
I hear ya, an extra 5 minutes divided by 10 years is no laughing matterI found 4 points (mostly control arm mounts) where I can run a 6ft chain and binder to 4 corners and be strapped down in less than 5 minutes. When you go wheeling as often as I do, it's important that it not be a major inconvenience
5 minutes is 10% of the 50 minutes per year I actually wheelI hear ya, an extra 5 minutes divided by 10 years is no laughing matter
Landscaping style trailer, lock the wheels hard one way and put the gate upChains and straps are not necessary. If the vehicle is in park with the e-brake on there is no need for anything else.
Winch cable for safety.Landscaping style trailer, lock the wheels hard one way and put the gate up
