All lights working as designed including highbeams. Aimed properly.
Side view mirrors, at least the left. Rear view mirror on inside as well.
If it has reverse lights, it can only have 2 and no "over ride switch". Must not be able to be lit in foward gears. (hide the switch) Not manditory.
Mechanical e-brake that works.
Wipers that work.
Tight front end components. No more than 3" off free play for steering wheels under 18" dia.
Windshield can not be busted in the drivers view.
Exhaust has to exit the rear or at least clear of the body. Passenger side is the only "foward of tire" exit allows.
License plate light, supposed to be visable from 50 ft, white only.
Red tail lights.
Horn, must be heard for 200 foot nor too damn loud.
Front or rear spring are noticable sagging, broke, cut, heated or removed/missing. (Hummmm, what about air shocks?)
Power steering must not leak and belt must be tight.
Turn signals must work. red or amber on rear, amber or white on front, switch has to be convienent for driver.
Can not have knots in the tires.
Thats pretty much it as long as it has the emissions stuff it came with for the year it should pass.
