I dont think his tool has a fast enough sample rate. It's possible there's an airflow problem hence the low load.O2s should be switching above and below that .450 constantly between .1 and .9v Fuel trims will go to 0 when in power enrichment, which in that truck is most likely above 90% throttle, otherwise the LTFTs should be moving around +- 10 ish
Sent from my SM-G955U using Tapatalk
