91samurai
- Apr 20, 2016
- Midland, Nc
I'm wanting to change the axle gears in my 91 suzuki samurai. The rear axle is a 91, but the front is unknown because of the 2wheel-4wheel drive conversion. I currently have the stock 1.3 and a toy 250 carb, 4-1 tcase gears, stock axle gears, and 31in ltbs. The motor has definitely seen better days. My main problem is the zuk is GUTLESS on the street. It won't pull 4th gear on a flat road, on the gravel road at uwharrie I often have to downshift into 1st for steep hills, like those near the art-liley camp ground. On the trail I can't use 4 high, in the mud i'm in 4-lo, second-third gear. The final straw in wanting a gear swap was at the shop, I kept stalling in the rocks because it didn't have low enough idle. I'm just a rock crawler, I really don't like bouncing my way up stuff. I'm looking for more low end torque and slowing the truck down while crawling.
My first question is, has anyone had any trouble with the gear swap? I know i'll have to buy a retainer sleeve and spacer.
My second question is 5.12 or 4.57? I understand those are the common junkyard options. In the future I plan to swap in the 1.6 8 valve I have sitting waiting to install(EFI ) Would 5.12s get me into high range on the trail? or would it be to low? I like to occasionally hit mud(when there aren't any rocks). Would 4.57s be low enough to crawl with but high enough keep it in one gear in the mud? (can't shift gota keep the power on!) The stock 4lo seemed about right on the street and gravel roads.
I'm planning to stay on stock axles for a while and not having to swap gears again(even with motor swap) Also I am planning to stay on 31s; its a good size for my rig.
Sorry for writing a book about this, I just want to be informed.
