Sway Bar Link Length?
Danger_Ranger
Star NC
I put a 3 inch lift on my xj and I want to make some swaybar quick disconnects, do I need to make them longer, or can they stay the stock length? If they need to be longer, how long do they need to be?
thanks. I dont really know anything about it. The stock ones hooked back up fine but I didnt know if it was limiting the suspension that much or not.
I know when I was setting up my Currie Anti-Rock, you try to shoot for having the bar at least parallel with the frame. So make your sway bar as level as you can with the frame of the vehicle, I believe further up is better than further down..
J.R.
Yeah, Like HANO said..... think about it, the further down they point, the less they can travel downward.... Likewis, the further up they are, the less they can travel upward..... so if u want to tune it you can, do you want ur axles coming further up or down? I wouldnt want them pointing up too much though, if you try to rig it so they have a shitload of downward travel, and then you stuff your suspension, it probably wont like you very much
