Hey guys.
So, my short bed Honcho needs a T400 transmission rebuilt and probably needs the trans cooler in the radiator flushed. My issue I’ve run into is the truck is a work in progress and isn’t registered or insured to be on the road currently. I have gotten a quote from a local shop with an iffy reputation to do the whole job for around $1200 if I bring them the truck, but they can’t test drive it afterwords to make sure the shift points are correct and all that fun stuff.
My other thought process so save a little money on labor is to pull the trans and radiator myself. Inspection plate is already out so I could have it on the ground in an hour or two. But, if I install it myself I am potentially at the mercy of installing it wrong or something being wrong with it to begin with and not find out till later or have a leg to stand on with the shop that rebuilt it.
Any thoughts or ideas? The truck drives and stops as far as I have been able to move it before the last trans went. Should I stick the tires on it that it’ll have and just let a shop do all the work so I know it’ll be right when I get it back? Any of you know a local shop that has a back lot they can run it around on so it can shift? Assuming they still test transmissions by driving them
haha
Picture of the truck in question.
hahaPicture of the truck in question.
