Tach install 22r need help installing
LarrySmith89
Conway NC
im installing a tach in my 86 22r and got it hooked up where the light works when you turn the headlights on. grounded to fender, but i cant get it to show the rpms. theres a red, white, green, black
anyone know how to hook this up? its a Super Tach II
Red= battery positive
White= light
Black= Ground
Green= ignition trigger, on the Toyota, there is a rubber capped green plug with a single wire near the ignition coil ( IF the truck does not already have a factory tach) This is where your Green wire connects, >DO NOT ALLOW THIS WIRE TO GROUND OUT< it can fry the igniter and will also short the ignition and not allow the truck to run
i have it all hooked up like that,, it might have a short or bad ground or something, the tach worked in the other yota.
still wont work, imma go buy a new tach and see if it works
