I brought home a hp 44 from the fords yesterday well we got 2 of them for spare parts 130 an axle not bad took 3 hours to remove both in the rain and only hand tools. Thanks chris
pull a part in charlotte They had a 78 and 79 bronco they put on the lot thursday so friday morning I took off. I also have a question about the hubs I need the toyota/ chevy lug pattern but I am aiming for High steer so what spindles do I need.
73-76 if I'm not mistaken.
You'll probably need a new driveshaft I'd imagine.
But the yoke is all technically, I'm not sure of your specific situation with the toy driveshaft so.
You can make a square tube front shaft and weld a Ford yoke to the end of it. My personally I wanted a nice high quality shaft so I ran shafts from High Angle Driveline front and rear. For $99 Jess offers an adapter flange for the D44 that will replace the pinion yoke on the D44 and allow you to use a flange w/ a Toy U-joint. B/c of how mine was set up it allowed my front and rear shafts to be interchangable
