RIDDLE29 New Member Joined Jun 23, 2009 Location canton Dec 22, 2009 #1 A buddy bought a 07 tacoma had prob getting it in 4 low and now he can not get it out help
DieselWhale Active Member Joined Feb 3, 2008 Location Lincolnton Dec 22, 2009 #2 Try putting the transmission in neutral then if it is an electronic shift select 2 hi if manual put in neutral and shift to 2 hi
maulcruiser Well-Known Member Joined Aug 13, 2005 Location Bladenboro/Wilmington, NC Dec 22, 2009 #3 He might need to let it roll slowly (less than 5 MPH) while working the front tires back and forth to release the bind on the driveline. If that doesn't work, dealer time.
Bain Member Joined Jun 5, 2009 Location lenoir Dec 22, 2009 #4 If it doesnt come out if you're rolling back and forth while trying to shift it out then yea...its time to get looked at
1badz2nv fustercluck extraordinaire Joined Jan 3, 2008 Location Dunn Dec 24, 2009 #5 seems like you had to hold the brake,in neutral, to go between lo and high. had one in a while back and it left me scatchin my head for a little while
Hyperlite Well-Known Member Joined Apr 19, 2005 Location merica Dec 30, 2009 #6 check to see if the floor mat is in the way of the pedal
