I have an 82 CJ8 that is making a tapping sound. The rythem is the same as engine RPM. My guess is a clutch bolt area sound.
What is the easiest way to get at this to check? It is a manual tranny, T176. From looking at it I think I need to pull the tranny in order to get at the fly wheel bolts to check those. Is it possible to pull the tranny back without removing to do this work?
If I have to remove, what all do I have to do? Here is what I think I need to do but have never removed a tranny.
1. Disconnect battery.
2. Disconnect drive shaft from xfer case.
3. Remove skid plate.
4. Remove xfer case.
5. Remove shifters
6. Disconnect clutch linkage.
7. Remove starter motor.
8. Support tranny, disconnect bolts, drop down.
5. Remove shifters
