- Apr 16, 2005
- Sharon, SC
are you using an efi dizzy??
found a guy that says he can llok at the jeep while its running then create a custom chip for $250, is that a decent deal. Thanks
aah you mean distributer, don't know how do I tell
I know the chips from Affordable Fuel Injection, where I got mine, are $95, but those are programmed to the harness you order or to your specifications of what sensors you will be running with you old harness, etc. Still, $250 seems steep to me.
got wires going into it other than power....
P.O Here, It is a EFI distributor. Everything on that engine is for EFI. I would try another pressure regulator in the top of that TBI. It was replaced but probably 2 yeare ago and it did alot of sitting with fuel in it.
You think it would make a difference since the pump is running only 15psi?
I know for a fact you can run higher pressure pumps. I have run mine on a SMPFI pump which puts out 60 psi but just for testing. Lots of guys do run the higher psi pumps but I think they blow by the regulator and possible damage it in long term use. If teh OEM spec is 10-12 that's what I'd try to stay around. Just what I did
No. ONLY 15 psi is about the top of the recommended TBI pressure. Should run fine at 11-14 psi. If you have a steady 15 psi DON'T mess with anything thereI know for a fact you can run higher pressure pumps. I have run mine on a SMPFI pump which puts out 60 psi but just for testing. Lots of guys do run the higher psi pumps but I think they blow by the regulator and possible damage it in long term use. If teh OEM spec is 10-12 that's what I'd try to stay around. Just what I did
