Tellico map update
Red arrows indicate the direction I like to run the trails. 4,5 & 6 can be run in either direction. Coming down School Bus can be done but not recommended. Same with Helicopter & Guardrail. There you usually run into too much traffic coming up and it's takes as long to get down as going around 3. Fain's Ford is getting some nice lines to the left coming out of the river. Upper 2 is getting more interesting. Peckerwood step is getting taller. Lower 2 not quite as hard as it used to be. Slickrock getting harder in spots. School Bus is the best and longest. Just my .02.
Something I noticed last weekend. It seems the upper part of 6 is closed. We were running up the "yellow" part of 6 and saw a "trail closed" sign about where it should have cut off. Unless I missed the connector, which I doubt, 6 goes directly into Peckerwood if you don't head down 4 instead. Also, the upper part of 4 was developing a nasty slip off the side of the hill. I don't know how much more traffic this slip can handle before it gives away. I'd hate to see it go when someone is on it. It's a long way down to the first large tree.
