TeraFlex high steer system
Mark -
We recently used that setup on a YJ that we did a SOA on (The "Nothin' Fancy YJ"), and it worked great. It's well built, and for the price, a very good option, in my opinion - especially after you price out steel, bungs, and the other items needed to build your own steering. We purchased it through DC, www.dc4wd.com
- Mac
X2 it is a good product. But if you can find a set of WJ knuckles, they relocate the tie rod/ DL higher than stock. They will probably be cheaper than the tera stuff and you can run the bigger WJ brakes for more stopping power.
I had the Tera on the YJ but didn't like the aluminum rods much and the 1 ton ends hanging of the bottom of the knuckle were too low. I have done both the Tera high steer knuckle and the MORE on SOA YJs and I like the MORE better but it is over-priced for what you get. Try the WJ idea if you have the raisins.
