TF727 with what xfer?
99ncxj
Aliso Viejo, CA
i picked up a tf 727 today that used to have a dana 20 bolted to it so it has the bull gear sticking out of the end. i need to know what xfer case can i use and what will it take to work on that output on the tranny. and it needs to be driver side drop. thanks.
Sounds like you mat have a 727 from a 1980 scout, it had a Dana 300 with the "texas" pattern of the dana 20. I'm not aware of any 727's that actually came with a dana 20 attached(could be though, anythings possible).
I think you would be better off to find a 727 from an '80 up full size Jeep as they had the more commen 6bolt/23 spline output.
yes, it has the texas 5 pattern. It may have had a 300 originally but it had a 20 on it more recently. should i get a new tail housing with the 6 bolt or try to find a xfer case that will work.
