Pinkston
- Mar 21, 2005
- Mebane, NC
The transmission in my buddys buggy is a th350 behind a 6.0. Recently it seems like it has started slipping in reverse. 1, 2, and 3 seem fine. In reverse it takes more gas than normal and then it will get moving.
The other issue that we noticed today is that there is some movement in the flex plate / torque converter. We noticed a slight tick at idle, got to looking around and you can see the flex plate moving in and out a little as its running. Rev the motor and it goes away, no ticking and no moving in and out. Is it out of balance? With the motor off we did some pocking around and everything feels tight.
We are going to fall crawl and he is trying to figure out if he can get one last trip out of it before taking it apart. Any ideas?
