TH350
1stgenxxx
Hudson
I bought a bad? trans to use as a case donor. The donor is a TH350C which has the plug for the electronic TCC. Can I use the guts from my older model th350 in this case without complications?
__________________
I figured this out today....The upper internals will work in either housing but only a ECC valve body will work in an ECC housing. I was going to use this housing and VB but the TCs bring the suck.
