cburgin
- Mar 20, 2005
- statesville/boone NC
Will a th400 drain to much power from a stock jeep 4.0L? Also will it be driveable at all on the street with 5.13s and 40s as fair as it being a 3spd with the gearing?
Its a 4.7 stroker. When I ran regular compound tires, it would sit in one spot and blister the rear tires, by just flat footing it, no brake. It won't exactly do that with stickies.whats the slight increase on the 4.0L?
With almost comparable gearing (and the 700R4 you have is actually lower than the TF999 or TH400, if I remember right), I don't see why it would drain power. You would however have to get a CPS relocating kit from AA if you went the route without the jeep tranny.
A friend of mine had a th400 behind a 4.3 chevy and it was a dog. He changed to a th350 and the performance was an amazing difference. When multiplying the gear ratio of the 700r4 and the ratio of the th350 or th400 it's alot of difference. With the 4.0 I can't see the need for th400.
th350 and th400 are no difference in power drain...a 700r4 has a lower 1st and would be better than both as far as low end grunt.
There is a power usage difference between the th350 and the th400. The th400 uses about 60 hp to operate, the th350 uses about 40hp to operate. I think the 700r4 and the th350 are the same hp usage.th350 and th400 are no difference in power drain...a 700r4 has a lower 1st and would be better than both as far as low end grunt.
Your crawl ratio is still only going to be around 46:1.
THe th400/203/205 is a very strong setup. I'm running a 700r4/231/300 and I have a crawl of around 117:1. With the 203/205 setup the only gear selectios are 1.9 or 3.6.
With the 231/300 the choices are 2.62, 2.72, 7.12.
Just some food for thought.
Also, if I decide later to go to a 5.3 or a 6.0 ...
And you say only 46.1 but the TC almost doubles that and I would think that would plenty for an auto, correct? What gears are you running to get a 117.1 crawl? my numbers using 5.13s on your combo doesnt give me 117.1. Also, if I decide later to go to a 5.3 or a 6.0 the stock 231/d300 would be useless IMHO. With my way I am more than 3/4 closer to having a one ton drive train...
I've read those numbers....Ive seen different on dynos.
About 60 could look a lot like 55 and about 40 could look a lot like 45 then there is a 10hp difference and a good tune up can net that..... just food for thought.
BTW your crawl numbers seem off to me, but Im in a rush I will check the math later.
FWIW, I got 50.380704 as the ratio.
TH400 = 2.48
203 = 2
205 = 1.98
Axle = 5.13
