The 2013 12 Days of NC4x4 WINNERS Thread!
trailhugger
Human Resources
Administrator
Raleigh
Day 12 - How We Roll
The Day 12 winner will receive FOUR NEW TIRES from Brandon at Rides of Conover.
Rides of Conover provides custom fabrication services for all your 4x4 needs. They're also a dealer for a wide variety of automotive accessories. I've even seen some nice street rod work come out of his shop. Drop Brandon a line if you have any questions.
Today's winner will also receive a 2014 Uwharrie Season Trail Pass, an NC4x4 koozie, and a lifetime NC4x4 subscription!
The Day Twelve winner is... #101 technologyteacher!
Day 11 - Disc Jockey
Today's winner will receive a disc brake conversion kit from Shawn Miller at Lug Nut 4x4.
These kits contain most everything you need to convert an axle to disc brakes, including:
3/8″ thick laser cut brackets
DOM bracket spacers (when needed)
grade 8 anodized mounting hardware
new Chevy rotors
rebuilt Chevy calipers with steel pistons
semi metallic brake pads
new inner hub seals
caliper pins
rubber flex hoses
banjo bolts with copper washers
anti-rattle clips
Shawn offers kits for Dana 60s, 14 bolts, 10.25s, Eatons, and even Ford front Dana 44s and 60s. Check out his website for the full list or send a PM to GubNi.
Today's winner will also receive a 2014 Uwharrie Season Trail Pass, an NC4x4 koozie, and a one year NC4x4 subscription.
The Day Eleven winner is... #242 NCDieselWrench!!!
DAY 10 - Weekend Warrior
Today's winner will receive a WarriorWelding gift certificate, valued at $300, good for fabrication, mechanical work, &/or raw materials.
Today's winner will also receive a WarriorWelding T-shirt, a 2014 Uwharrie Season Trail Pass, an NC4x4 koozie, and a one year NC4x4 subscription.
The Day Ten winner is...#58 ncsutj !!!
DAY 9 - Round is a Shape
Today's winner is taking home a fabricated heavy duty steering kit from Metalwerx Design & Fabrication!
Don't start the New Year all bent out of shape! Replace that bent up steering with a heavy duty steering kit from MetalwerX Design and Fab!
This kit includes:
  • Two pieces of 1 1/2" OD 1/4" Wall DOM tube, cut to length and bent as needed to fit your application!
  • Four Barnes Heat Treated Chromoly Heims...3/4" Lt hand and Rt hand thread
  • Four Weld-in threaded tube inserts
  • Four Misalignment Spacers
  • Four Safety Washers
  • Grade 8 hardware with NYlock Nuts
The Day Nine winner is... #99 2010nctaco !!!
DAY 8 - Deal of the Day!
Today's winner will receive a Gift Certificate for $200 to Barnes 4WD!
index.php
Barnes 4wd strives to be a leader in the four wheel drive industry, carrying a wide range of off-road parts for the hard core rock crawler to the customer just getting into off-roading.
Today's winner will also receive a 2014 Uwharrie Season Trail Pass, a 1-year subscription to NC4x4, and an NC4x4 koozie!
And the Day Eight winner is... #30 Mulishajoe!
DAY 7 - A Shocking Development
Today's winner is taking home a set of four BDS 5500 series shocks, courtesy of Tarheel 4WD Center!
index.php
The Day 7 winner will also receive a Tarheel 4WD Center T-shirt, a 2014 Uwharrie Season Trail Pass, a 1-year subscription to NC4x4, and an NC4x4 koozie!
And the Day Seven winner is... #123 Redneck92!
DAY 6 - There's No Place Like Home​
Today's winner will receive an MBRP stainless exhaust tip (up to 6"), gas or diesel, a T-Shirt, and decal from High Impact Diesel!
The Day 6 winner will also receive a 2014 Uwharrie Season Trail Pass, a 1-year subscription to NC4x4, an NC4x4 koozie!
And the Day Six winner is... #227 novacayne75!
DAY 5 - No Time For Losers​
Today's winner will receive an ECORS tool bag, an ECORS 20' tow strap & an ECORS t-shirt! The Day 5 winner will also receive a 2014 Uwharrie Season Trail Pass, a 1-year subscription to NC4x4, an NC4x4 koozie!
And the Day Five winner is... #125 5keepers!
DAY 4 - You can call me Susan if it makes you happy​
Today's winner is taking home a Snatch Block from Bailey's Towing Accessories!
index.php
Bailey’s Snatch Block is perfect for off-road enthusiasts who want a commercial-grade snatch block that is affordable and made in the U.S.A. (Youngsville, NC) The 4-inch-steel sheave is machined to a smooth finish for use with synthetic winch lines and wire rope up to 7⁄16-inch. A self-lubricating bronze bushing is pressed into the sheave for maintenance free use and the design of the laser-cut side plates allows you to rig the block in seconds, utilizing the large opening for a variety of rigging options. All steel parts have corrosion-resistant zinc plating for durability. The Bailey’s Snatch Block has a working load limit of 9,000 pounds and a tested ultimate breaking strength of 41,000 pounds.
We've gotten a lot of use out of ours at URE work days!
And the Day Four winner is... #246 NCJeyota!
NCJeyota will also receive a 2014 Uwharrie Season Trail Pass, a 1-year subscription to NC4x4, and an NC4x4 koozie!
DAY 3 - Up All Night (to Get Lucky)​
Today's winner will receive a 2014 Uwharrie Season Trail Pass, a 1-year subscription to NC4x4, an NC4x4 koozie, and a swag bag from one of our favorite vendors, Carolina Axle and 4x4! This swag package includes a shirt, hoodie, and decals!
And the Day Three winner is... #121 doc!
DAY 2 - Future's So Bright​
Today's winner will receive a 2014 Uwharrie Season Trail Pass, a 1-year subscription to NC4x4, an NC4x4 koozie, and a $50 Gift Certificate from one of our newest vendors, Southern Suicidal Lighting!
The Day Two winner is.... #142 13bullets!
DAY 1 - Excess ain't Rebellion​
We are on the way to Uwharrie, actually, so our rock and roll lifestyle means that this first post will have to do without photos...
The Day One winner is: #48 dcain1979!
And he's in luck...
In I could use a good bacon sampler pack!!
Along with a 2014 Uwharrie Season Trail Pass, an NC4x4 koozie, and a 1-year subscription to NC4x4, dcain1979 will receive an America's Best Country Bacon Selection from Father's Country Hams!
13bullets wins every year. I hate that guy. :p
This is actually the first time I've won anything in my life. I won a big stuffed cow at a fair once when I was a teenager, but it cost me $37. o_O
Lol I know that feeling, and Im just giving you shit because I also never win anything, but I have won my fair share of carnival toys at the expense of my wallet and often pride!
And the Day Two winner is... #121 doc!
And he's in luck...
So....day two has TWO winners ???? You must have been up all night !! Congrats to the winners so far !!
