catfishblues
- Jul 26, 2005
- Pfafftown, NC
"This is a Kicker made box. Its measurements are... 9 1/2 inches deep at the base of the box, 15 inches high, and 17 1/2 inches wide. The box is made of thick wood and is solid. The box also includes a kicker grill and a kicker trim piece that matches the older style kicker amps that had removable end caps. With this box there is a 10 inch Kicker L7 subwoofer. The sub has sat in storgae for a long time unused. The coils read out correctly when ohm'd but the speaker is stiff. It plays and handles wattage fine but sounds odd. The voice coils just need 2 be oiled and the sub should play perfect again. I drilled a hole in the cone and shot some wd40 down in it, it helped but it really needs voice coil grease. If not send it in to kicker for a discount on a new L7. Either way its win win because its cheap. You can hook the sub up and hear it play. $40 cash takes it. The box and speaker grill are worth that alone. Pics of both are below. If interested please text 864-580-9626 or reply via email. No calls please due to a busy work schedule. Thanks."
Anyone know where I can get voice coil grease? Kaleco was fresh out when I called.
