The Goat Trail?
Gman
Hey guys,
I apologize if this isn't the correct section. A friend of mine told me about this trail a couple weeks ago but couldn't tell me how to get there. I tried searching here and found mention of it being at or around 12 mile. I was hoping to get directions from somebody so that I can plan a trip out there.
Thanks in advance!
Some important info is needed, like where, as in what area is it supposed to be near. I will tell you for sure, if it's a public trail, in NC, it would be known here. That said, if I am correct, it is probably a power line or right of way that is being used, illegally.
There is a dirtbike trail called the goat trail at brushy Mtn., but I doubt that is what you are referring to unless your friend is very confused.
It is a legal trail in the Harmons den (12 Mile area) but last I heard they gated it when all the trouble came up at Max Patch. I haven't been down there in a year or so, so maybe someone that has been will chime in.
If you come from the bottom its would be easy to get lost getting to it. But if u come from the top its not hard to find. But like Pless was says it maybe closed and gated now. Have not been to it in a while. Easiest way would be to fallow someone up thought it and then u would know and not get lost.
Where are u from? And what do u drive?
I live just outside of Asheville. I drive a Land Rover Discovery. I'm bored with Hurricane Creek and looking for another legal area to go that is closer than Uwharrie.
It's still quite a drive from you, but there is lake houser. Not sure if itd be worth the drive, and you would most definitely need somebody with you that knows the trails.
Hey, its closer than uwharrie anyway...
