willness33
Here for the memes
- May 3, 2005
- Alexis,NC
I laughed and snorted thinking of the 20 some half bottles of brake fluid on my garage shelf.
False. I always remember to add power steering fluid when the pump starts to whine.Also - power steering fluid is unquestionably the most overlooked and forgotten about fluid.
I had a 2003 chevy 2500hd that had a small power steering leak on the return side. For some reason, I took it to the dealer in Shallotte, NC while I was down at the beach and had them replace the line and bleed/flush the power steering system. I could not believe how much of a difference it made. The sharp turn whining was gone, and it just felt better throughout the entire range of motion.Also - power steering fluid is unquestionably the most overlooked and forgotten about fluid.
Sticking w/ my every 5k on the 5k
For everything except my new car, we do oil changes and tire rotations on 5k intervals ending on 0 and 5. Why? Because I can look at the odomter and say, "Oh its time to change the oil by about next weekend".
Mathematically this maybe costs be $30 more annually than doing it according to the stated rule here... and for $30 I'd rather do what's easy to ensure it's done.
I've always wondered why it isn't typical to have a drain valve or some other easy way to flush PS Fluid. Every vehicle I've owned ypu have to either disconnect a hose or suck it out the reservoir.Also likely the hardest one to change. Flushing out the box could be a bear without taking it apart.
FIFYIts like the engineers know people will not flush it.
Its like the engineers are begging people to not flush it.
That suburban still have AFM? My mom has an '07 that has 160k miles or so and was using a good but of oil. Turned off AFM in the tune and the oil consumption reduced dramatically.I've got a '11 suburban 1500 and an '07 camry, both renowned oil disappearers. They each get topped off so often I never really need to drain it, just change the filter once or twice a year.
. It typically consumes between 1/2 - 3/4 qt every 1k miles depending on driving. Not sure if it's worse doing highway miles or around town.Also - power steering fluid is unquestionably the most overlooked and forgotten about fluid.
Which of them isn't technically a sealed system?no need to think about it when it’s a sealed system.
Sealed as in you can’t check the fluid. There is no reservoir or dipstick to check.Which of them isn't technically a sealed system?
Maybe oil, b/c the dipstick isn't really sealed?
