orange150
- Mar 20, 2005
- Fairfax City, VA
Threw out my rear driveshaft for the second time this year in my 250.
First time: looked like one of the bolts on one of the u-joint straps on the yoke vibrated out, causing the shaft to let fly.
Today: broke a head off one of the bolts on one of the u-joint straps on the yoke, causing the shaft to let fly.
Both times happened while starting from a red light, not goosing it or anything, just casual driving.
Wondering if both instances are coincidental or if there is a cause to the problem?
Also the best method of getting the broken bolt out, just drill and tap? helicoil? ....?
If it makes a difference the rear end is your run of the mill 10.25 w/ limited slip & 4.10s
