Erik
- Oct 20, 2005
- Wilmington, NC
I'm startingt o get a shopping list for the parts i will need to cplete my front end's 4 link setup.
i don't know a whole lot about it, but i understand you can run with or without a trackbar... still unsure of the pros and cons of each method
i know i can runs coils and springs, coilover-springs, or air shocks... not interested in elliptical setups.
BTF has some sweet coil mounting buckets that use 2.5" (or maybe it was 3") coilover springs and the buckets/perches for both sides of the front end are about $80...... definatly looks pretty sweet....
i was looking at air shocks bc of how adjustable they are, and since i could technically just mount them to my existing shock hoops and axle tube shock mounts..... simple enough it seems..... but does anyone run them on the street? i want my yj to ride like a long armed tj.... smooth, predictable, etc.....
coilovers are expensive, but damn nice, and quite possibly worth the cost to me if i could get the ride quality i wanted with the huge assortment of spring rates and heights out there.....
coils and shocks are the most cost effective, but will also have the most guesswork associated with them, not to mention not nearly as tuneable for a smooth ride and great flex....
well then comes link choice. i was thinking 1.5" DOM with .25 wall and welding in threaded inserts, but then i was given the idea of running 1.75" DOM and tapping the threads into the tubing itself..... suggestions?
then comes my rod ends... heims? ok, what size? big ass 3/4" shanks? or is that overkill? what about johnny joints? what links would i use those on?
what about the geometry? what would be the best choice for a great riding mall queen? what about a hardcore off road only rock crawler? i want to be in between there somewhere with the least bit of compromise but i don't really understand where to start.
swaybars.... skyjacker, currie, teraflex, or an oem sway bar? ugh.... front and rear, or only front? time will tell....
as you can see, i am clueless. i take that back, i know what i think i want, but that will change daily up until the day everything is installed and i'm too broke to change my mind again.
some things i'm trying to keep in consideration.... i don't want to have to carry more than 2 extra links for trail spares..... i'll eventually swap in a small block... 350 or a 360 most likely..... i'll be buying parts slowly over the month month or two... or three.... so finding deals here and there would be nice.
ok, so let's here what you have to say. i hope to hear that air shocks will be great because they are a bit more affordable, but i don't see that being a reallity.
-Erik <--- would appreciate any links to relevant information as well
