herbnuts3
- Dec 15, 2009
- jacksonville
I was doing a tuneup on my burban when i busted the ear off of the distributor that the cap bolts to. I replaced the distributor and then had to take it to the dealer to do the final timing do to the computers on the vortecs... They got it to run more smoothly, but told me they couldnt reset the check eng light because the crankshaft position sensor was throwing a constant code... I replaced it, took it in to reset with no luck. I know notice a ticking, like a loud rocker or valve sticking or something(I rev to 2k rpms and i hear the tick keeping pace with eng speed)the check eng light is still on and it misses at all RPM ranges. I dont know if i bought a bad sensor, if i have a failing injector, or if the distibutor i purchased was faulty?
any help will be greatly appreciated guys!!! i need some input on where to start...
