Cameron Harris
- Oct 19, 2014
- Wilmington NC
throwing together my hp Dana 44 and ford 9" build, and I am hung up on the issue of tire size. It will be under my Cherokee, 231/300 doubler (7:1 total low) and 5.13s in the axles. Will be locked front and rear. 9" is the big bearing newer housing from 81, and the front is a 76 ford 5 lug high pinion Dana 44. Do I go 37s or 39.5 rockers? I am currently geared and locked on factory axles (d30 and 8.25) and repeatedly break shafts up front, and don't want to be in the same boat with throwing tires on the 44 that will be right in the border line. Any advice and help is appreciated.
