Only the 2000-2006 versions do. The early TJs used a single outlet manifold.The TJ versions have two seperate outlets on them. Wasn't sure if there would be any power gains by switching over. And my down pipe is about flat where it crosses under trans anyway.
i've put them on older meaning xjs without them. u have to make the gasket work though which is a pain to get not to leak but it's doable. never tried it on Renix being that old, plus the renix is (for me anyways) twice as strong as the newer 4.0sTell me how you installed the later "double manifolds" on Remix heads. Specifically while using Remix intake manifolds?
It's not a bolt and go swap.
The two piece obviously flow better, that's simple physics. Their shorty design aids in building better low end torque and promotes better balanced cylinder scavenging.
