tj codes p0016 and p0339?
explorer redneck
old fort
Its a 05 tj with the 4.0. Its giving the two codes in the title. It started acting like it was redlining around 3000 rpms. Then after i cut it off it does it around 4000 or45000 rpms. Just changed the crank sensor in the bell housing. What esle could it be. Also were is the cam position sensor at?
P0339
Test 1 - 2
180215131
Test 3 - 6
180215132
Test 7 - 11
180215133
Test 12
180215134
SYMPTOM
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
WHEN MONITORED
While cranking engine and engine running.
SET CONDITION
When the CKP Sensor failure counter reaches 20. One Trip Fault.
POSSIBLE CAUSES
  • Good trip equal to zero
  • CKP wire harness inspection
  • (F855) 5-volt supply circuit open or shorted to ground
  • Tone wheel/pulse ring inspection
  • Checking CMP sensor signal with the DRBIII(R) lab scope
  • Crankshaft position sensor
  • (K24) CKP signal circuit shorted to battery voltage
  • (K24) CKP signal circuit open
  • (K24) CKP signal circuit shorted to ground
  • (K24) CKP signal circuit shorted to (F855) 5-volt supply circuit
  • PCM
© 2012 ALLDATA LLC. All rights reserved.
Terms of Use
Test 1
180208927
Test 2 - 5
180208928
Test 6 - 9
180208929
Test 10 - 11
180208930
SYMPTOM
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
WHEN MONITORED
Engine cranking and Engine running
SET CONDITION
Powertrain Control Module detects an error when the camshaft position is out of phase with the crankshaft position.
POSSIBLE CAUSES
  • Intermittent condition
  • CMP wire harness inspection
  • Intermittent CMP signal
  • Intermittent CKP signal
  • Camshaft position sensor
Terms of Use
I have no idea what is up with the stuff I posted from alldata. I swear it was right when I posted it. Earlier it had diagrams of an axle now its got a/c stuff. Let me know if you need any of the diagnostic stuff and Ill email it to you.
