TJ Drive Shaft
redneck_leprechaun
Eden
I am puting a 4" Super Lift on my TJ and plan on putting 33" Super Swamper LTB tires on as well. I know that I am going to need a new driveshaft but the question that I have is how big of a drive shaft will i need to fit with this lift?
You won't need a new DS unless you get a SYE kit.
Then you would need to get the measurements after doing the lift to see what length DS you'd need to get.
When you order the SYE most places would know about how long of a CV driveshaft to give you.
BUT it is MUCH better to measure and make sure something isn't wonky and you'd need a different length.
If you are just doing the tcase drop, you won't need a new DS.
I originally put the same brand lift on my TJ w/33's, I used the transfer case drop and drove it as a DD and weekend offroader w/ no problems. If you are installing a Slip Yoke Eliminator it's best to follow hscrugby's advice and measure before ordering a new drive shaft.
