tj front markers dont work
mossyoaktj
Member
so the marker or running lights whichever you prefer on my tj dont turn on. only in the front tho, the tail lights works just fine. however the turn signals do work in the front. we are getting power through the harness on both sides but nothing to the light. and like i said the turn signal works fine, could it just be the plugs it self since everything else is getting power.
I posted in your other thread but did you replace the bulbs with dual filament bulbs. If they are single filament then only the turns will work.
i replaced them with the ones that came with the jk lights, the bulb has both strands on the inside. the old bulbs stopped working as running lights as well
Switch the blinker and hazzard thingy in the fuse block.
