tsouther
- Aug 11, 2008
- Mars Hill NC
I have a 98 Wrangler,2.5 5speed with trouble code P0204 Injector#4 control circuit/#4 output driver does not properly respond to the control signal. Problem started with a little skip then rough idle that would smooth out after 2800 rpm now it just runs rough all the time and has a strong gas smell from the exhaust. I replaced the Injector,and can't find any broken wires. Could this be a pcm/ ecu problem? Any help would be greatly appreciated. The engine runs the same with the injector unplugged as it does with it plugged up.
