Estonian
Member
- Oct 25, 2008
- Raleigh/Garner
i own a 97 wrangler TJ that HAD the 2.5 motor in it. But last week i finished my 4.0 swap out of a 02 wrangler TJ... and now i need a heater box so i could have HEAT in the car which would be very helpful this time of the year. The 97 heaterbox i have in there now will not work with the new heater controls because its all electronic but the 97 model uses pull cables, and i have thought through every possible option to make it work but NO luck. Now the question is that does a cherokee xj share the same heaterbox as a wrangler TJ? if it does then i could go to a local pull apart LKQ salvage yard and get one for $50. And if NOT then maybe somebody on the board has one, (it can be A/C or not ) i need it to fit a 02 model, not sure the years that fit i think its 02-06 but not sure. thanks alot.
