TJ / LJ Dana44 4.88 ARB rear axle *broken*
LBarr2002
SC
Original rear axle out of my 2004 LJ for parts or whatever...
Passenger side shaft broke in the splines and took out ARB case half and boogered up the housing.
-4.88 Ring and pinion is good
-Drivers side shaft is good.
-ARB main case and internals is good. One ride on new seal housing.
-calipers and powerstop brakes on it
I'll take $250 for all. If separate $100 for gear set, $50 for shaft, $50 for brakes, $150 for ARB stuff.
If I had a need, I'd...
Why you have to go and break that....?
A tj one or JK? Later this year my HP30 4.88 ARB will be available, assuming I don't break it too.
Dont break it and ill buy it.
Had to thrash and get the JK44 in for a trip in FEB. I'll probably run the 30 for that trip and maybe one on April, then it will come out. And front 44 in.
